Regulated power supply
Discussion in 'Homework Help' started by NTCM, Apr 17, 2013.
  1. NTCM
    Apr 17, 2013
    8
    Dear all
    Could you please help as soon as possible
    for the below project i need the circuit diagram and theory calculation
    (Design and implement 8.2v Regulated power supply using full-wave bridge rectifier (use zener diode for voltage regulation)
  2. #12
    Nov 30, 2010
    16,704
    7,354
    This isn't a free engineering service. It is rare that we work out a full schematic for anyone, especially in a manner of doing their homework for them.
  3. WBahn
    Mar 31, 2012
    18,088
    4,917
    Is there any particular format they we should use? Should we save you the hassle of turning it and just submit it directly to your instructor for you?
    If you want "help", then you need to show YOUR efforts to solve YOUR homework problem (for which YOU will receive a grade and WE will receive NOTHING). If you put in an honest effort, you will find the people here will bend over backwards to help you find your way to a solution. But if you just want the work done for you, you will discover that this becomes a pretty harsh place.
  4. NTCM
    Apr 17, 2013
    8
    Dears
    Just i want to Guide me, support and how i will start from member experince
  5. t06afre
    May 11, 2009
    5,939
    1,222
    Well perhaps your books can offer some help for your project. You have also your good old friend google. A quick google search with "full wave rectifier" may help you out. The first hit in the list is this http://en.wikipedia.org/wiki/Rectifier
    NTCM likes this.
  6. WBahn
    Mar 31, 2012
    18,088
    4,917
    My "member experience" is telling me that you aren't interested in putting in any effort on your own and just want a handout. That doesn't get you far here.
    You need to post SOME attempt at a solution. It doesn't have to be much. But keep in mind that we start from YOUR attempt, so the more effort you put into that the quicker things will get moving.
  7. bountyhunter
    Sep 7, 2009
    2,498
    507
    Hard to sympathize..... all you have to do is a Google search for power supply circuit, do a screen snag on the image and post that as a starting point.:p
  8. NTCM
    Apr 17, 2013
    8
    after searching i connect the element as sequnace
    the input is 220/240 v output 8.2v
    1-Transformer (for step down)-2-Bridge diodes-3-Capacitor-4-zener diode
  9. NTCM
    Apr 17, 2013
    8
    Many Thanks dear for guide :) i want like this step by step that i can learn i will add my diagram after test
  10. t06afre
    May 11, 2009
    5,939
    1,222
    Should it not be a resistor in series with zener. If not the zener will go up in smoke ;) Again refer to your school books about this
  11. WBahn
    Mar 31, 2012
    18,088
    4,917
    This is not an adequate description of your circuit since there are numerous ways to connect them up. Please provide some kind of diagram. It doesn't have to be fancy. Paint will work just fine.
  12. NTCM
    Apr 17, 2013
    8
    I hope to give me your opinion about the circuit i draw using multisim after reading the information from internet and i saw many diagram i you have any comments please advice (the Voutput 8.2 v using zener diode as regulater see the attachment
      File size:
      55.5 KB
      17
  13. t06afre
    May 11, 2009
    5,939
    1,222
    NTCM likes this.
