Regulated power supply Calculation
Discussion in 'The Projects Forum' started by Paras Bhanot, Mar 23, 2016.
  1. Paras Bhanot
    Jun 22, 2015
    hello everyone ,
    i am working on home automation project in which Micro-controller (atmega328p ) is used . This micro-Controller is powered by Regulated power supply . I want to calculate Total power consumption in KWhr so that i can calculate my monthly electricity bill if i run my circuit 24/7.
    To simplify Calculations i replaced atmega32p with simple led. Then i measured input rms voltage and input rms current using multimeter on input side as shown in my attached circuit. i have got the following results ->
    V(rms) = 220 v and I(rms) = 6.6 mA
    So P(rms) =V(rms) X I(rms) = 220 X 6.6 mA = 1.45W
    in KWhr = (1.45W x 24 hrs) /1000 = 0.03484 which is obviously wrong
    Note : Cost of 1 unit = 8 bucks in my country
    What is the correct way to calculate Total power consumption.
  2. #12
    Nov 30, 2010
    16,704
    7,352
    You forgot to multiply by days in a month.
  3. hp1729
    Nov 23, 2015
    2,098
    232
    34.8 watt-hours per day. Sounds right. 0.034 kilo-watt-hours per day.
    What is your billing period? Monthly? Quarterly?
  4. Paras Bhanot
    Jun 22, 2015
    it is Monthly .
  5. hp1729
    Nov 23, 2015
    2,098
    232
    Then, as suggested, times 30 days for the month. About 1 kw/hr a month.
  6. Paras Bhanot
    Jun 22, 2015
    thanks
  7. ronv
    Nov 12, 2008
    3,401
    1,471
    Isn't there a sine or cosine involved here?
  8. crutschow
    Mar 14, 2008
    13,501
    3,375
    For true power, yes.
    They actually calculated apparent power since the power factor wasn't included, but that's likely close enough to the real power for the purposes of the calculation. It is a pessimistic value so the real power will always be less.
