Regulated DC supply - need help with calculations
Discussion in 'General Electronics Chat' started by ankit_mcgill, Mar 14, 2012.
  1. ankit_mcgill
    Mar 14, 2012
    Hello All,
    I am in the process of making a regulated power supply to convert AC(220V, 60Hz) to DC(9V, 500ma). I have worked out all the calculations and would appreciate if someone could double check just to make sure they are alright.
    My setup is as follows
    AC(220,60Hz) -> Transformer(12V,500ma) -> Bridge Rectifier -> Voltage Regulator(7809)
    1. the 78xx series requires at least 2V to work => i need at least 11 as rectifier output
    2.the ac input might vary by 10% ..
    peak transformer voltage = 12 * 1.414 = 16.97V
    min transformer voltage = 16.97 - 1.697 = 15.27V
    vout-bridge = vmin-transformer - (2-0.7) - Vripple
    vripple = 15.27 - 1.4 - 11 = 2.87
    dt * load current / C = 2.87
    C = 8ms * 500mA / 2.87
    C = 1393 μf
    can someone confirm this is correct ??
    thank you for the help !
    ankit
