regulated DC power supply
Discussion in 'Homework Help' started by alexan, Oct 8, 2006.
  1. alexan
    Oct 1, 2006
    Hi all,
    Do u know how to make a 0-10V adjustable DC power supply, supplied from 240 Vac?
  2. mrmeval
    Distinguished Member
    Jun 30, 2006
    AC->stepdown transformer->three terminal regulator->out
    Amperage will be of concern as this does not provide much but this is an example.
    In the example you would want to replace the transformer and the 7805 with probably a 240VAC to 24VAC transformer and a 7810 if you can find one. You'd get rid of the other outputs and just use the 10V three terminal regulator
    Tutorial on linear power supplies
    If you need hyper efficiency for some reason then you'd be more interested in switching supplies.
