regulated bulk converter
Discussion in 'Homework Help' started by alexan, Oct 15, 2006.
  1. alexan
    Oct 1, 2006
    hi all,
    how to design a closed loop regulated buck converter that can produce a variable output voltage of 0 ~ 10V and is able to supply up to 10A load current at any output voltage?
  2. Dave
    Retired Moderator
    Nov 17, 2003
    6,960
    145
    You may wish to post up any attempts you have made to this question, if you are expecting and help. You might also be advised for the benefit of those not in the know, state what a "closed loop regulated buck converter" is.
    Dave
  3. Papabravo
    Feb 24, 2006
    10,340
    1,850
    An LTC1775 with an external switch should be capable of doing the job. Get a copy of LTSpice for the complete circuit.
  4. n9352527
    Oct 14, 2005
    1,198
    It's probably not a good idea to design one with such a wide output voltage range. Unless you have a compelling reason to do so. Switchers work best at the designed fixed output voltages.
    Incidentally, I've never seen one with output that goes as low as 0V. If you think about it, it kind of makes sense.
