Regulated +/- 12V from a 12V supply
Discussion in 'General Electronics Chat' started by sdh314, Dec 23, 2011.
  1. sdh314
    Jun 2, 2011
    18
    I'm trying to hunt down a regulator that can produce a regulated +/- 12V supply from a 12V battery pack. Ideally I'd like it to have an enable/shutdown pin that can be controlled via a uprocessor and reduce the quiescent current to a few uAs or less. Does anyone have any suggestions? I've been searching for a few hours and can't seem to find one with the necessary specs.
    Thanks!
  2. debjit625
    Apr 17, 2010
    790
    186
  3. praondevou
    Jul 9, 2011
    2,936
    489
    An important information is missing: what's the max current for the negative supply?
    I could recommend a switched capacitor voltage inverter IC like the LT1054 but you can't draw too much current from it.
