I'm sorry was talking about the difference in memory architecturesEach architecture is going to be its own critter. That goes for CPU architectures as well as memory architectures. So you need to focus the discussion on specific architectures.
I'm concerned with the difference in physical architecture of register file sram and a standard sram (which includes the decoder architecture, precharge and sense amplifier circuits).Though i know the read/write operation at gate-level or transistor-level in an sram, not sure if its the same or different in register file(knowing the rf architecture would probably help me understand).Thank youThere is tremendous differences in the architecure between a register file and regular memory. Both can be accessed in the same way, logically speaking. Can you restate your question more specifically?
Thread starter | Similar threads | Forum | Replies | Date |
Atomicity of STM32 register writes | Microcontrollers | 3 | ||
L | reading and writing to a register file without bypass | Digital Design | 7 | |
What is register file? | General Electronics Chat | 11 | ||
T | MIPS datapath register file problem | Homework Help | 0 | |
T | register file in verilog | Programming & Languages | 4 |
by Jake Hertz
by Aaron Carman
by Duane Benson
