Register Clock Gating
Dritech
Joined Sep 21, 2011
901
Hi all,
I was reading the article in the link below, where it says:
"Because the D-type flip-flop does not have a hold mode and will always cause the copying of its D inputs to the Q outputs on every clock pulse, we gate the clock (not nice) to allow conditional load of the register."
Why is it 'not nice' to use such layout?
http://faculty.kfupm.edu.sa/coe/ashraf/RichFilesTeaching/COE022_200/Chapter 5.htm
Thanks in advance.
Hypatia's Protege
Joined Mar 1, 2015
3,228
Asynchronous gating of the CP may cause unexpected operation at certain 'junctures'.
Then, too, it is less than 'elegant' ;)
Should you insist upon this method, you are best advised to implement a gating circuit that prevents -- but can neither cause nor be asserted during -- a clock transition...
Best Regards
HP
Papabravo
Joined Feb 24, 2006
21,225
The whole idea of a synchronous system is that all the registers are updated at the same time, on the clock edge. Any gating delay will cause that register's output to change later than all the other ungated registers.
34,451
If the clock happens to be asynchronously gated at the rising edge of the clock then you many get a very short clock pulse (glitch) at the gate output which may or may not clock the register (for a positive edge-triggered FF).
The proper way to gate a clock is to use another flip-flop to control the gate. The gate control would go to the D input and an inverted clock to the FF's clock input. The reason for the inverted clock is so the gate transition occurs at the following edge of the clock and thus won't cause any glitches on the rising (sensitive) edge.
WBahn
Joined Mar 31, 2012
30,060
The description appears to be talking about gating the clocks to individual registers when those registers need to be held. If ALL of the registers always need to be held or updated at the same time, then what's the point of gating a clock as opposed to just using a clock at the right frequency?
Any time that you have an edge-sensitive circuit you have to pay very careful attention to race conditions and timing hazards. These are not the easiest things to deal with since they often involve layout-specific influences such as trace routing. So it is best to design your logic to be fully synchronous wherever possible. There ARE advantages to asynchronous designs, namely speed, power, and gate count, but the additional significant cost of good design and verification have to be weighed against them.
Papabravo
Joined Feb 24, 2006
21,225
BTW, the cannonical way to do this, especially inside an FPGA, is to use a 2 input multiplexer on the D input to route either the Q output or the present input to the D input. Problem solved and no messing with the clocks.
