Regenerated
Discussion in 'Wireless & RF Design' started by KL7AJ, Aug 11, 2014.
  1. KL7AJ
    Thread Starter AAC Fanatic!
    Nov 4, 2008
    2,047
    295
    Just picked up a cute little MFJ Regenerative SW receiver at the local ham flea market. I forgot how sensitive these little puppies are! Great fun....amazing what you can do with 3 transistors! :)
  2. MrChips
    Oct 2, 2009
    12,643
    3,457
    Cool :cool:
    I will have to try a regen myself.
  3. BR-549
    Sep 22, 2013
    2,184
    421
    In the June 1998 QST there was an article on an OCR Reciever by N1BYT. ORC---optical coupled regenerative. I bought the board only from Jade products for $5. I only set it up for 40 meters. But it has a socket for the other bands. AM, SSB and CW. I use a random wire with a rca jack for ant. Very cheap to build. Very sensitive and very stable. It uses 2 nine volt batteries, long life. Works perfect to this day.
  4. alfacliff
    Dec 13, 2013
    2,449
    428
    I put together a little one tube regen with one 6418 tube, it runs off two 9 volt and one AA batteries. real neat how those one tube designs work so well.
  5. alfacliff
    Dec 13, 2013
    2,449
    428
    if am reception is all thats required, try a "superregenerative" reciever, less adjusting of the feedback.
  6. BR-549
    Sep 22, 2013
    2,184
    421
    In the early 70's, a buddy and I were studying for our ham code test. We both built transistor regens. He lived about a block away. It was very easy to hear each others receiver. We hooked up our keys. We were well prepared for that test.
  7. alfacliff
    Dec 13, 2013
    2,449
    428
    thats why a lot of ship recievers got modified with rf amplifiers in early ww2, u boats were homing on their recievers.
    BR-549 likes this.
  8. BR-549
    Sep 22, 2013
    2,184
    421
  9. KL7AJ
    Nov 4, 2008
    2,047
    295
  10. alfacliff
    Dec 13, 2013
    2,449
    428
    I got an nc300 national reciever at a sidewalk sale and its a great ham band only recieverf. a real hernia generator, it weighs about 65 pounds.
    cliff wa0rox
  11. BR-549
    Sep 22, 2013
    2,184
    421
    You lucky dog. You probably doubled your money on the copper alone. Does it work? These are great old machines. Tubes always catch my attention. I like to see that 6418 circuit.
  12. alfacliff
    Dec 13, 2013
    2,449
    428
    the circuit is in makeradio.com, the usuall ticklercoil regen with the only differences being an extra resistor in the filament supply since it only runs on 1.4 volts at 10 ma, resistor is to drop usual 1.5 volt battery to 1.4
    the nc300 works great, doing an alignment on it now, and cleaning up a little. the 5 lb flywheel tuning knob makes it real smooth. with 14 tubes, it warms up a little, but not too bad.
