regarding the max232(rs232 level converter)
Discussion in 'Embedded Systems and Microcontrollers' started by a.salah, Apr 5, 2009.
  1. a.salah
    Mar 24, 2008
    11
    i connected the max232 with its components(4 1uf capacitors).
    in the datasheet of the max it says that if the pin T1in or T2in received low voltage the o/p will be high if the i/p is high then the o/p is low.
    in my case the i/p voltage is 1.5v and the o/p is 3.7v !!!
    should the o/p be 12v to transmit the signal to serial port?
    i am supplying the max232 with Vcc=4.6v so what's wrong with it?
  2. thatoneguy
    Feb 19, 2009
    6,357
    718
    The Max232 is an inverting voltage doubler.
    1.5V is below the minimum threshold (2V Guaranteed, 1.5V typical) for a high signal. Check the datasheet
  3. a.salah
    Mar 24, 2008
    11
    i tried to input 2 and 3.5 voltages but the output still very low?
  4. thatoneguy
    Feb 19, 2009
    6,357
    718
    Post a schematic of the entire circuit, the problem may be somewhere else, or it could be connected wrong in wiring.
  5. a.salah
    Mar 24, 2008
    11
    now the first problem is solved but there is another problem
    after supplying the max232 with Vcc(5v) i noted something strange
    pins #10 and #11 are input pins but when measuring the voltage on them the multimeter reads 5v!!!
    it's supposed to be 0 because i want to input TTL signal and max232 invert it to Rs232 level.
    Note: i tried two different max232 ic's but the two have the same problem?
    Thank you
  6. eblc1388
    Nov 28, 2008
    1,542
    102
    Said who? :mad:
    The internal schematic clearly shows two 400K pullup resistors on pin#10 and pin #11. This will cause your DVM to measure about +5V even when nothing is connected to these pins.
  7. a.salah
    Mar 24, 2008
    11
    Pin 10,11 voltage being +5v makes the T1out and T2out -12 v so the serial device receives -12v all the time which may interrupt the communication and causes unexpected behavior from the device
  8. thatoneguy
    Feb 19, 2009
    6,357
    718
    When connected to logic, it will be held at 0 or +5. Are you not using it for this purpose? The pullup is to help open collector outputs of some logic ICs.
