Regarding PIC timer interrupt
Discussion in 'Embedded Systems and Microcontrollers' started by elsanthosh, Dec 23, 2008.
  1. elsanthosh
    Dec 23, 2008
    Dear sir,
    this santhosh , i need a asm code for PIC timer interrupt . i am using PIC 12F510 microcontroller.
    thank u
    santhosh babu
  2. jpanhalt
    Jan 18, 2008
    5,699
    909
    Are you sure the 12F510 supports interrupts? John
  3. elsanthosh
    Dec 23, 2008
    dear sir,
    this santhosh ,i need a asm code for timer in 12f510 microcontroller. i need to generate for 100msec timer.
    thank u
    santhosh babu
  4. jpanhalt
    Jan 18, 2008
    5,699
    909
    If all you want is a 100 mS pulse, go here:
    http://www.piclist.com/techref/piclist/codegen/delay.htm
    Enter your data (pulse width, frequency), and it will generate the code for you. You may need to use retlw instead of return, but your programmer/assembler will probably catch that error and automatically fix it. I use a PicStart Plus/MPLab, and it does that.
    John
  5. abhijeetscience
    Dec 24, 2008
    :(i have optical encoder with 30 slits with 300rpm motor how many (instructions)inputs can a picaxe 28X1 handle .. will they be sufficient for my encoder :confused:
  6. nanovate
    Distinguished Member
    May 7, 2007
    665
    maybe what does the datasheet say?
