regarding matched filter
Discussion in 'General Electronics Chat' started by elisettynarendra, Oct 28, 2010.
  1. elisettynarendra
    May 17, 2010
    42
    can anyone explain how a matched filter increases S/N (signal to noise ) ratio....i referred wikipedia but the equations given there are difficult for me to understand ..plzz explain in simple language ..
  2. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    An active filter (one that uses semiconductors and resistors) will increase the S/N ratio due to noise generated in the semiconductors and resistors, sort of like the broadband "fffttt" noise you get when water is squirting out of a garden hose nozzle.
    A passive LC filter does not add appreciable amounts of noise, as the main components are L (inductive) and C (capacitive). There are some minor parasitic components of R (resistance) inherent in capacitors and inductors, but it is generally quite low.
  3. Ron H
    Apr 14, 2005
    7,050
    657
    The key word here is "matched". I don't have any experience with matched filters, but I understand the concept, if not the math. Googling "matched filters" (I'm sure the OP doesn't want to hear that) brings up lots of complicated explanations.
