regarding interfacing sd card with pic 18f4520
Discussion in 'Embedded Systems and Microcontrollers' started by k.gopalakrishnan, Nov 8, 2010.
  1. k.gopalakrishnan
    Jun 18, 2010
    http://img442.imageshack.us/img442/8744/mmcconnection.jpg
    this is the circuit diagram i followed, and my code is
    Code ( (Unknown Language)):
    1.
    2. #if defined(__PCM__)
    3. #if defined(__PCH__)
    4. #endif
    5. #endif
    6.
    7. #include <stdio.h>
    8. #include <string.h>
    9. #include <mmcsd.c>
    10. #include <input.c>
    11. #fuses XT,NOWDT,NOPROTECT,NOLVP
    12.
    13. #use delay(clock=4000000)
    14. #use standard_io(B)
    15. #use standard_io(C)
    16. #use standard_io(D)
    17.
    18.
    19. #define LCD_ENABLE_PIN PIN_B0
    20. #define LCD_RS_PIN PIN_B2
    21. #define LCD_RW_PIN PIN_B1
    22. #define LCD_TYPE 2
    23.
    24. #define SPI_SDI PIN_C4 //PIN 23
    25. #define SPI_SDO PIN_C5 //PIN 24
    26. #define SPI_SCK PIN_C3 //PIN 18
    27. #define SPI_SS PIN_C2 //PIN 07
    28.
    29. #define SPI_MODE_0 (SPI_L_TO_H | SPI_XMIT_L_TO_H)
    30. #define SPI_MODE_1 (SPI_L_TO_H)
    31. #define SPI_MODE_2 (SPI_H_TO_L)
    32. #define SPI_MODE_3 (SPI_H_TO_L | SPI_XMIT_L_TO_H)
    33.
    34.
    35. void lcd_init();
    36. void lcd_cmd(cmd);
    37. void lcd_data(data);
    38. void nibbel_split(unsigned long DataIn);
    39.
    40. int mmc_init();
    41. int mmc_response(unsigned char response);
    42. int mmc_get_status();
    43. int mmc_write_block(unsigned long block_number);
    44. int mmc_read_block(unsigned long block_number);
    45.
    46.
    47.
    48. unsigned char cmd,data;
    49. int i,j=0;
    50. int res,rcvdat;
    51. char send_data[]={"TRANSINNOVA INSTRUMENTS PVT LTD"};
    52. int read[32];
    53. int DDLN,DDUN,LN,UN;
    54. int errvalue;
    55.
    56. void main()
    57. {
    58.
    59. set_tris_b(0x00);
    60. set_tris_d(0x00);
    61. set_tris_c(0x10);
    62.
    63. lcd_init();
    64. lcd_data((mmc_init()+0x30));
    65. output_low(PIN_C2);
    66. }
    67.
    68. int mmc_init()
    69. {
    70.
    71. setup_spi(SPI_MASTER|SPI_MODE_0|SPI_CLK_DIV_16);
    72.
    73. output_high(PIN_C2); // set high slave select signal before sending cmd0
    74. output_high(PIN_C5);
    75.
    76. for(i=0;i<10;i++) // initialise the MMC card into SPI mode by sending clks on
    77. {
    78. SPI_WRITE(0xFF);
    79. }
    80.
    81. output_low(PIN_C2);
    82.
    83. spi_write(0x40);
    84. spi_write(0x00);
    85. spi_write(0x00);
    86. spi_write(0x00);
    87. spi_write(0x00);
    88. spi_write(0x95);
    89.
    90. if( mmc_response(0x01)==1)
    91. return 1 ;
    92.
    93. i = 0;
    94. while((i < 255) && (mmc_response(0x00)==1)) // if = 1 then there was a timeout waiting for 0x01 from the mmc
    95.
    96. // must keep sending command if response
    97. {
    98. SPI_WRITE(0x41); // send sd command 41 to bring out of idle state
    99. SPI_WRITE(0x00); // all the arguments are 0x00 for command one
    100. SPI_WRITE(0x00);
    101. SPI_WRITE(0x00);
    102. SPI_WRITE(0x00);
    103. SPI_WRITE(0xFF); // checksum is no longer required but we always send 0xFF
    104. i++;
    105. }
    106. if(i >= 254)
    107. return 1; // if >= 254 then there was a timeout waiting for 0x00 from the mmc
    108.
    109.
    110. OUTPUT_HIGH(PIN_C2); // set SS = 1 (off)
    111.
    112. SPI_WRITE(0xFF); // extra clocks to allow mmc to finish off what it is doing
    113.
    114. OUTPUT_LOW(PIN_C2); // set SS = 0 (on)
    115.
    116. SPI_WRITE(0X7A);
    117. SPI_WRITE(0X00);
    118. SPI_WRITE(0X00);
    119. SPI_WRITE(0X00);
    120. SPI_WRITE(0X00);
    121. SPI_WRITE(0XFF);
    122.
    123.
    124. OUTPUT_HIGH(PIN_C2); // set SS = 1 (off)
    125. SPI_WRITE(0xFF); // extra clocks to allow mmc to finish off what it is doing
    126. OUTPUT_LOW(PIN_C2); // set SS = 0 (on)
    127. if((mmc_response(0x00))==1)
    128. return 1;
    129. OUTPUT_HIGH(PIN_C2); // set SS = 1 (off)
    130.
    131. return 0;
    132. }
    133. int mmc_response(unsigned char response)
    134. {
    135. unsigned long count = 0xFFFF;
    136.
    137. while(SPI_READ(0xFF) != response && --count > 0);
    138. if(count==0) return 1; // loop was exited due to timeout
    139. else return 0; // loop was exited before timeout
    140. }
    141. void lcd_init()
    142. {
    143. cmd=0x38;
    144. lcd_cmd(cmd);
    145. delay_ms(250);
    146. cmd=0x0E;
    147. lcd_cmd(cmd);
    148. delay_ms(250);
    149. cmd=0x01;
    150. lcd_cmd(cmd);
    151. delay_ms(250);
    152. cmd=0x06;
    153. lcd_cmd(cmd);
    154. delay_ms(250);
    155. return;
    156. }
    157. void lcd_cmd(cmd)
    158. {
    159. output_d(cmd);
    160. output_low(PIN_b2);//rs
    161. output_low(PIN_b1);//read write
    162. output_high(PIN_b0);
    163. delay_ms(250);
    164. output_low(PIN_b0);//enabel
    165. return;
    166. }
    167. void lcd_data(data)
    168. {
    169. output_d(data);
    170. output_high(PIN_b2);//rs
    171. output_low(PIN_b1);//read write
    172. output_high(PIN_b0);
    173. delay_ms(250);
    174. output_low(PIN_b0);//enabel
    175. delay_ms(250);
    176. return;
    177.
    178. }
    179.
    180.
    i am expecinh 0x00 in my lcd display it shows blank or i am suspecting that my sd card is working or not. if any one having the test program kindly send to me.kindly help me out of this problem.
  2. tom66
    May 9, 2009
    2,613
    214
    Microchip have a Memory Disk Drive library which implements support for SD cards, including FAT32, over SPI, for PIC18F/24F and dsPIC30F/33F. Try that before writing your own library.
  3. k.gopalakrishnan
    Jun 18, 2010
    where i can find memory disk library for sd card provided by microchip
  4. cheezewizz
    Apr 16, 2009
    82
    10
  5. davebee
    Oct 22, 2008
    539
    46
    SD and MMC cards work about the same after initialization, but they have different initialization sequences. The SD initialization is something like sending a series of 0x41/0x55 characters until the card responds with a ready signal. The code you have is probably almost ready to work, so if you modify it with the correct SD initialization sequence it would probably work.
