regarding diode
Discussion in 'Homework Help' started by gaya3eeee, Aug 23, 2006.
  1. gaya3eeee
    Aug 18, 2006
    7
    why resistors used in testing "the forward and reverse characteristics of diode" gets burned when high current is passed?
  2. Dave
    Retired Moderator
    Nov 17, 2003
    6,960
    145
    I'm sorry but I don't understand the question, can you clarify what exactly you are asking? You may benefit from reading this.
    Dave
  3. n9352527
    Oct 14, 2005
    1,198
    Umm... because the resistor power rating is too low?
  4. Papabravo
    Feb 24, 2006
    10,340
    1,850
    High current in a resistor causes heat which must be dissipated by conduction, convection, or radiation. To compute the power in a resistor you square the current and multiply by the resistor value. If the current is expressed in Amperes and the resistance is expressed in Ohms then the power will be expressed in Watts.
    Example: An IR-LED has the desired brightness at a forward current of 150 mA at a forward voltage drop of 2.2 Volts. The supply is +5 VDC. The resistor for this application is 18 Ohms. Compute the required power dissipation rating of the resistor
    Code ( (Unknown Language)):
    1.
    2. (0.150)*(0.150)*18 = 405 mWatts
    3.
    If you use a quarter watt resistor in this application the magic smoke will very quickly exit the resistor body with the usual fetid acrid smell.
    Remember the following piece of doggerel:
    "Twinkle-twinkle little star
    Power's equal I squared R"
  5. Gadget
    Distinguished Member
    Jan 10, 2006
    613
    What voltages are you using..?
  6. Dave
    Retired Moderator
    Nov 17, 2003
    6,960
    145
    Electronics for pre-schools :D
    Love the ditty.
    Dave
  7. Papabravo
    Feb 24, 2006
    10,340
    1,850
    Voltage equals I times R
  8. Dave
    Retired Moderator
    Nov 17, 2003
    6,960
    145
    Current equals V by R
    I can play this too :D
    Dave
  9. Papabravo
    Feb 24, 2006
    10,340
    1,850
    Never a dull moment with this crowd. Nothing better than snappy repartee.
  10. Dave
    Retired Moderator
    Nov 17, 2003
    6,960
    145
    You know it makes sense ;)
    Dave
