Regarding Adhesive For Bonding
Discussion in 'The Projects Forum' started by mishra87, May 30, 2016.
  1. mishra87
    Jan 17, 2016
    205
    Dear All,
    I want a adhesive for bonding.
    My application is to seal the cables, ICs, FPC connector, ON/OFF switch etc.
    it can be used in all components of PCB.
    Right Now I am using Fevibond and equivalent or hot melt glue.
    fevibond can damage static device in PCB like ICs.
    So could anybody recommend me exact solutions for this.
  2. jpanhalt
    Jan 18, 2008
    5,699
    909
    There are silicone rubber adhesives that are safe with electronics. They typically cure after exposure to moisture in the atmosphere. There are also 2-part adhesive rubber formulations used for potting.
    My first stop is usually McMaster Carr (mcmaster.com) just to get an idea of what's available. Then I hit Google.
    John
    mishra87 likes this.
  3. Kermit2
    Feb 5, 2010
    3,851
    967
  4. mishra87
    Jan 17, 2016
    205
    Thank you all.
    I do not want potting material .
    I have been using solution dobefil 60 and hardner for potting purpose.
    I want for glueing purposes.
    I tried several local brand like fevibond, anabond 20. They all fails.
    That's I asked in forum...!!!
  5. mishra87
    Jan 17, 2016
    205
  6. Kermit2
    Feb 5, 2010
    3,851
    967
  7. ian field
    Distinguished Member
    Oct 27, 2012
    4,447
    791
    Silicone RTV adhesive/sealant from the DIY store releases corrosive acetic acid as it cures.
    You can buy non acetic RTV for electronics work - one manufacturer I know of is Dow Corning.
  8. jpanhalt
    Jan 18, 2008
    5,699
    909
    Hence I specified silicone rubber safe for electronics. Thank you for underlining that comment.
    Also, Henkel (aka LocTite), which used to be based quite close to where I lived in Cleveland, offers a myriad of adhesive and sealants. You see its stuff holding SMD's during soldering operations and affixing wires.
    If the TS can give via examples what he needs, we can give narrowed suggestions. The fact that he has used hot melt, made me think that the electronic safe silicones might work.
    John
  9. jpanhalt
    Jan 18, 2008
    5,699
    909
  10. jellytot
    Member
    May 20, 2014
    72
