Refresh me please on Single-Supply ICSP Programming
Discussion in 'Embedded Systems and Microcontrollers' started by spinnaker, Jan 3, 2014.
  1. spinnaker
    Thread Starter AAC Fanatic!
    Oct 29, 2009
    5,062
    1,160
    I have been away for a while. I am not certain that I ever understood forgot. I see that Single-Supply ICSP Programming allows for the elimination of the 13v supply. So that field programming can be more easily done in the field.
    Does the PicKit2 generate the 13v? If so I assume it would generate it when the program is downloaded into the PickKit and it is later used to program a device?
  2. blueroomelectronics
    Jul 22, 2007
    1,758
    98
    The PICkit2/3 have a voltage multiplier on the VPP pin, usually between 8-13VDC.
