Refraction within a prism
Discussion in 'Physics' started by Sparky49, Sep 20, 2011.
  1. Sparky49
    Jul 16, 2011
    835
    417
    Hi all,
    I'm trying to prove that if I were to shine a beam of light into a prism at an angle of incidence 35°, then the angle of incidence where the light leaves the prisim is 38°. The prisim having a refractive index of 1.55, and being an equilateral triangle.
    However, I'm having abit of trouble with this.
    I'm aware of the rule: n=sin i/sin r
    and: 1/n=sin i/sin r
    but I still can't figure it out.
    Can anyone tell or show me the steps to achieve this?
    Thanks.
  2. davebee
    Oct 22, 2008
    539
    46
    Don't you also have to specify the angle between the entrance and exit prism faces?
  3. steveb
    Jul 3, 2008
    2,433
    469
    So he said "equilateral triangle" which I assume is referring to the shape of the prism. This would make the faces with a 60 degree angle.
    I'd like to see some work from the OP before helping. At least a drawing should be shown with the angles defined for clarity. Then an attempt to apply the refraction formula should be made so we can see where the conceptual problem is coming in.
  4. Sparky49
    Jul 16, 2011
    835
    417
    Certainly.
  5. steveb
    Jul 3, 2008
    2,433
    469
    OK, so i agree with your first calculation to get 21.72 degrees refraction angle.
    I think your problem is that you are not defining the angle of incidence on the other face correctly. The angle you show is the refraction angle (kind of), not the incident angle. I said "kind of" because usually the exiting angle is defined relative to the normal of the face, not parallel to the face.
    So basically, I think the angle of incidence you are looking for is inside the prism (what you call i2) and not outside. With this assumption, I calculate an angle of incidence of 38.28 degrees. Can you do it now?
  6. someonesdad
    Jul 7, 2009
    1,585
    141
    Consult any high school or college elementary physics textbook on the topic of Snell's Law. This would be a good opportunity to use a cheap laser and set up an experiment to try to accurately measure the ray deviations/geometry. You can mark things on a big piece of paper. When I do such things, I measure and mark angles on paper using a big drafting triangle (or a drafting machine) and use trig functions to measure angles (and tangents to lay them out). I use high-quality drafting rules and machinist's rules to measure the linear dimensions. With a sharp pencil and care, you can do good work, just like they did hundreds of years ago. :p
