It would be cheaper for me to buy capacitors that don't need reforming.Build a 250 V power supply. I use a variac to feed a microwave oven transformer. Then rectify, filter, and a resistor in series with the victim.
Get creative. Are you a wizard, or not?
Do you have a suitable transformer with the requisite ratio? You could probably get away with reversing the intended use and step up the line voltage a bit (as long as the ratio isn't too large), then run it through a full wave bridge and filter capacitor.
As long as transformers are involved and things are isolated, you could use two transformers/rectifiers as mentioned and put them in series to get the desired voltage.
Aren't you a student? If so, your school might have an old tube power supply laying around that you could use for this.
by Aaron Carman
by Duane Benson
