Reflow Controller ...
Discussion in 'General Electronics Chat' started by Dr.killjoy, Dec 23, 2015.
  1. Dr.killjoy
    Apr 28, 2013
    1,209
    158
    How do you guys flow your smd parts and what kind of paste or solder do you use.. I am possible looking to make a toaster into a reflow with a controller or use a pid controller.. I read alot of people just eyeball it and use a remote meter .
  2. tracecom
    Apr 16, 2010
    3,878
    1,396
  3. SLK001
    Nov 29, 2011
    850
    242
    I normally use a soldering iron and a 7-30X microscope to solder SMDs (I've spent many an hour slaving under a hot microscope!). If the component is a BGA, or has bottom pads not accessible from the top, then I bump the pads with solder, then use paste flux and a Weller heat gun. This was all done in a professional product development environment and this technique works well.
    The very fine pitch stuff can be a real challenge using this technique.
  4. Dr.killjoy
    Apr 28, 2013
    1,209
    158
    I saw the article but I got thinking and did alot of research .. I found I could use a arduino and LCD with k-thermocouple with amps chips..Then grab a servo for the door and a ssr and couple buttons .. All the parts can get cheap off eBay ..I can wire it up but my problems comes with writing the code and programming which I will most likely need help with..
