ref for geology
Discussion in 'General Science' started by killerfish, Jun 17, 2010.
  1. killerfish
    Feb 27, 2009
    17
    anyone can recommend which geology reference book contains info about weather, climate change, root of global warming, etc. My sudden curiousity, I want to know about these.:)
    your helps is greatly appreciated.
    Thanks.
  2. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,389
  3. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    I'm going to move this to General Science, as it's not quite physics.
    Have you looked in your local library? There are usually some titles on the subject of weather. I'm not too sure geology is really involved, unless you are concerned with volcanic gasses.
  4. killerfish
    Feb 27, 2009
    17
    Thanks I will look at it.
    Thanks. I don't have prior knowledge of these so I not sure about this. Im curious about root of climate change and the cycles, global warming(melt of north/south pole ice what will happen next). Hope you guys can enlights me. :)
  5. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    I'm not sure anyone has the root cause. The planet has gone through numerous warm and cold cycles. I don't recall anything convincing about what brought on the ice ages, or why things were able to warm up after so much ice formed.
  6. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,389
  7. retched
    Dec 5, 2009
    5,201
    313
    Mother Nature goes on benders some times and leaves the door open...
    ..Thats why we have ice ages. ;)
  8. sceadwian
    Jun 1, 2009
    499
    37
    And big bangs.
  9. Wendy
    Mar 24, 2008
    20,772
    2,540
    Actually one of the better explanations is our sun is actually a variable star, it is not as stable as we'd like to assume. If that is the case we are lucky it isn't worse.
  10. studiot
    Nov 9, 2007
    5,005
    515
    A good all round introduction is
    Atmosphere and Ocean - Our Fluid Environments
    By
    J G Harvey
    Oceanography
    By Summerhayes and Thorpe
    Is good on global warming, greenhouse effect, and climate change
