Reed Switch with delay
Discussion in 'The Projects Forum' started by bigfly203, Apr 25, 2016.
  1. bigfly203
    Apr 25, 2016
    I have no experience with electronics at all. I'm trying to override a gamepad controller button with a very simple reed switch circuit. I want to add a delay, where once the circuit is closed it stays closed for some amount of time (configurable or even just some constant) and then opens back up. What's the easiest way to go about doing this? Thanks
  2. Bernard
    Aug 7, 2008
    4,239
    414
    You could use a reed relay driven by a 555 chip configured as one-shot.
  3. bigfly203
    Apr 25, 2016
    That sounds pretty good, I would also need a battery to drive the whole thing?
  4. Bernard
    Aug 7, 2008
    4,239
    414
    Pick a power supply to match the reed relay, 5 V is common, 4 NiMH AAs rechargeable or 4 Alk. AA, AAAs.
