I am doing a project for university which required me to build a tachometer for a dc motor I built. I have so far set up a circuit with an LM2917 and LM3914 to LEDs. If I input a signal from a signal generator into the first pin of the LM2917, more LEDS light up for more frequency as it is suppose to be. I am now up to building the sensor for my motor. I have set up a reed switch however it pulses from 0volt to 3volt. I now think from the reading Ive been doing the 2917 needs a negative voltage as well like -1.5 to +1.5. I am using two 1.5V batteries for the reed switch so is there anyway to wire this like that or will I have to go with a different sensor. I am very new to this so sorry if some information is wrong. I tried doing the batteries like the attatched picture but dont know how to wire it to the reed switch.
