I'm trying to figure out the best way to lower the voltage for a transformer. As it stands the transformer converts from 120 to 14.5 - both VAC and the primary draws about 3.7-4 amp (that would mean ~ 33 amp on the 14.5v side). So the ratio is 8.276:1 I would like to get the voltage to 13.0vac which would mean that I should have a primary voltage of 107.59 VAC for the ratio to give 13v.
Now I'm not sure if the resistors should be used on the primary or the secondary. If everything was ideal I would be able to adjust the voltage from 103.45 - 111.73 which would give 12.5-13.5 on the secondary. I'm concerned about the current if putting the resitor on the secondary but I don't know if that is a valid concern or not.
What is the best way to calculate this and where should the resistor(s) go?
IDK if more info is needed but the output from the secondary will be put through a full bridge rectifier and have a smoothing cap.
