thank u it was useful !Depending on the part we are talking about it may be as simple as the external wiring. There will probably be no power saving from using half-duplex.
Here is a part that can be used either way: full duplex or half duplex.
http://www.ti.com/lit/ds/symlink/sn65hvd1476.pdf
Thread starter | Similar threads | Forum | Replies | Date |
P | Ultrasonic Transducer and Reducing the Power Output | Power Electronics | 7 | |
I | Reducing power on a 12V pump | Power Electronics | 10 | |
M | Reducing 110VAC to power a very small coil on a relay | Power Electronics | 44 | |
Reducing SW node ringing - LT3958 SEPIC converter | Power Electronics | 1 | ||
P | reducing motor power? | General Electronics Chat | 19 |
by Aaron Carman
by Jake Hertz
by Aaron Carman
