I put a new kawasaki engine on a piece of equipment that has many electrical relays to run electric hydraulic controllers. engine voltage regulator is putting out 14 v dc. Kawasaki doesn't have a differant regulator for this engine. I am told the relays will fail if i don't get them steady 12v current.
The inline fuse is 15amp to the control panel. Is there a inline current regulator that can reduce the voltage from 14vdc to 12vdc with 15 amp draw. As you can probably tell by my lingo i am not very knowledgeable about electronics.
Any suggestions would be very helpful in correcting this problem.
Pete
Pete
