Reduced power relay coil driver
Discussion in 'General Electronics Chat' started by timrobbins, Jun 7, 2010.
  1. timrobbins
    Thread Starter Active Member
    Aug 29, 2009
    318
    16
    Hi all, I'm just starting to prepare a design for a relay/contactor coil driver which has a reduced power hold state - to save energy loss in a solar powered application. I don't want to use a latching relay due to failsafe reasons.
    I have come across some black box products, such as the coil controllers from Albright - and Kilovac has a good read on their economiser http://www.penninecomponents.co.uk/News/PDFS/Kilovac_Data/economizer_presentation.pdf
    Has anyone attempted to put together a relatively simple driver based on say a 556 and a buck converter. The initial pull in would be a few seconds with the FET on, followed by a level of pwm duty cycle sufficient for acceptable hold in - and possibly an auxiliary contact to reset the timing. The coil would typically be a standard continuous duty coil. Or maybe I need to get a little more exotic.
    Ciao, Tim
  2. k7elp60
    Nov 4, 2008
    478
    69
    Deleted because information was not revelant on second thought.....guess I'm getting to old for these forums
  3. Bernard
    Aug 7, 2008
    4,235
    414
    A simple power reducing method is to use a resistor in series with coil to provide proper hold & parall R with a capacitor to provide inrush current to initially pull in relay.
  4. Bernard
    Aug 7, 2008
    4,235
    414
    Thanks for the sermon, kangyuta, but what does it have to do with relays?
  5. mcgyvr
    Oct 15, 2009
    4,787
    973
    Typically this is called an "economizer" circuit. Googling that term will yield a bunch of circuits to accomplish the task.
  6. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Google "PWM relay driver" for lots of results.
  7. timrobbins
    Aug 29, 2009
    318
    16
    Thanks guys,
    I am going to be using LP339 ic's elesewhere on the pcb, so have just gone through the circuit shown in Kilovac's paper for the CCC and have calculated the component values - not too difficult. I will use a FET instead of darlington, and don't need the rapid turn-off circuit, which simplifies things a bit. Itshould all be quite neat and tidy.
    Ciao, Tim
