Reduce the price challenge.
Discussion in 'The Projects Forum' started by manikant, Dec 28, 2015.
  1. manikant
    Nov 17, 2015
    6
    Hi friends,
    I am working on an IR remote controlled switch. There is only one receiver and one switch on transmitter remote. This switch is used to toggle the appliances connected at the receiver end. To avoid noise and interference I have used TSOP but it was not serving the purpose exactly (It was facing noise due to fluorescent lamp blast). So I have used HT12D/E encoder decoder IC at transmitter and receiver end to prevent the noise,now it is working perfectly. The problem is that this encoder/decoder IC is 4 channel and bit costly and I need only one encoding channel. So please suggest any cheap IC or alternatives available in the market.
  2. sailorjoe
    Member
    Jun 4, 2013
    361
    63
    https://learn.adafruit.com/ir-sensor/overview
    For a single channel sensor, maybe this is more like what you want. The transmitter sends a modulated IR IR signal to a detector, which ignores the fluorescent lights because it's tuned to the modulation frequency. The detector then tells you if it sees the signal or not. Inexpensive. Easy.
  3. AnalogKid
    Distinguished Member
    Aug 1, 2013
    4,685
    1,297
    1. Before you added the HT12, were you modulating the IR beam with any frequency or signal, or just turning the LED on and off?
    2. Was the fluorescent lamp noise causing your output to change when not intended, or not to change state when intended?
    3. What is the full part number for the TSOP device?
    ak
