reduce gain for transistor
Discussion in 'General Electronics Chat' started by karas, Sep 8, 2011.
  1. karas
    Thread Starter Active Member
    Sep 8, 2011
    127
    to reduce gain for transistor we put resistor between base and emitter can someone help me what the effect of R that it lower the gain
    thanks
  2. vrainom
    Member
    Sep 8, 2011
    109
    19
    I'll give you a hint: bipolar transistors' output current (collector-emitter junction) is proportional to the current flowing through the input (base-emitter junction). So if you place a resistor parallel to the input...
    TAKYMOUNIR and karas like this.
  3. Adjuster
    Dec 26, 2010
    2,147
    300
    Such a resistor reduces the current gain, but does not stabilise it. For this we normally apply negative feedback.
    @ vrainom: Is that nickname in line with the recent Google+ ruling?
  4. vrainom
    Member
    Sep 8, 2011
    109
    19
    It's from an Yves Bonnefoy poem I like, and also kind of a word play since it means "true name"
