Reduce a 30 V sine wave to 3.3 V
Discussion in 'General Electronics Chat' started by user127, Jan 25, 2013.
  1. user127
    Jan 25, 2013
    12
    Hello everyone,
    I'm currently working on a project where I use a TI DSP to sample a ultrasound signal. Sadly, I have envountered a problem. The pulser I'm using sends out a pulse with an amplitude of 30V, while the input of the DSP only takes 3.3V. My question is therefor: How can I reduce the amplitude of the signal without changing the sinusoidal morphology of it? It might be worth mentioning that the frequency of the signal is 5MHz.
    I've read that transformers, transisors, step down converters, operational amplifiers and simple voltage dividers can be used. Is one of these a good option or can anyone recommend a suitable method?
    Thanks in advance!
  2. t06afre
    May 11, 2009
    5,939
    1,222
    I can not see why a resistor divider should not work in this case. But put a suited OPAMP between the divider and the ACD input. But another problem. Can you DSP sample with at least 10MHz samplerate?
    user127 likes this.
  3. MrChips
    Oct 2, 2009
    12,622
    3,451
    A voltage divider using two resistors would be the simplest solution.
    You may want to add a couple of diodes to clamp the voltage between Vcc and GND so that you don't blow your chip.
    user127 likes this.
  4. user127
    Jan 25, 2013
    12
    @t09afre
    I use the DSP TMS320F28335 from Texas Instruments which can sample in 12.5 MHz, hence, over the nyquist frequence. Why should I use an amplifer after the resistor divider?
    @MrChips
    Do you have any schematic for such a circuit, with the diods that is.
  5. MrChips
    Oct 2, 2009
    12,622
    3,451
    user127 likes this.
  6. ScottWang
    Aug 23, 2012
    4,923
    776
    5MHz/30V → resistor divider (3V) → Op Amp Voltage follower(3V) → 3.3V clamp → ADC
    Op Amp Voltage follower(3V) - for isolation.
    user127 likes this.
  7. user127
    Jan 25, 2013
    12
    So, I should first use a resistor divider to get 3V over one of the resistors used (ex. 27kOhm and 3kOhm). Then I should isolate the circuit with the help of a OP amp follower. Last, I should use a 3.3V Zener diode and a resistor as a clamping circuit, which gives me the output over the Zener diode. Have I understod this correctly?
  8. #12
    Nov 30, 2010
    16,655
    7,293
    Seems right from here.
    user127 likes this.
  9. Ron H
    Apr 14, 2005
    7,050
    657
    WHy do you need to preserve the sine wave? Are you going to digitize the transmitted signal? I would think that you would be digitizing the return signal, which will be low amplitude.
    PackratKing and user127 like this.
  10. user127
    Jan 25, 2013
    12
    I need to preserve the waveform because the knowledge about the frequency components can help me find possible echoes.
    Yes, both the transmitted and received signals will be digitized. This is done mainly because the pulser/receiver also "receives" the transmitted signal, and because I need to calculate the distance between both of them.
  11. user127
    Jan 25, 2013
    12
    When I simulate this with pspice (OrCAD) I get a phase shift at the out signal. How can I avoid this?
  12. t06afre
    May 11, 2009
    5,939
    1,222
    A bigger problem might be this. Looking at your chip. It has only ADC unit capable of 12.5 MSPS. If you are sampling two ADC channals. These two has to share 12.5 MSPS between each other and end up with a half the sample rate.
  13. ScottWang
    Aug 23, 2012
    4,923
    776
    Did you simulate as I mentioned?
    You can separate each stage and to see the waveform, then you will find that where is the problem.
  14. Ron H
    Apr 14, 2005
    7,050
    657
    Why is phase shift a problem?
  15. user127
    Jan 25, 2013
    12
    @t06afre
    I'm only using one analog input so that will not be a problem. But thanks for the information.
    @ScottWang
    Yes, I simulated as u mentioned and came to the conclusion that the zener diode was the problem. But now I'm thinking about skipping the diode because I'm already restricted by the feeding voltage of the op amp. If I feed it with 3.3v, the output will not exceed 3.3v. right?
    @Ron H
    If the signal is shifted then I need to sample more points making my sample array in my program much larger. This will lead to longer execution time.
    I'm also wondering which op amp I should choose in othe words can all op amps handle 5MHz signals. Maybe LM6132 a good choice?
  16. ScottWang
    Aug 23, 2012
    4,923
    776
    MSP430 Vcc=2.5V~5.5V, you can check your DSP.
    If your DSP as MSP430 then you can choose a 3.6V Zener or a little higher.
    If you want to get a 3.3V from Op Amp, then you better offer the Vcc=5V, because the output of Op Amp will reduce about 1.4V from Vcc, you can find out the infos from the datasheet of Op Amp.
    user127 likes this.
  17. Ron H
    Apr 14, 2005
    7,050
    657
    Scott, have you heard of rail-to-rail op amps?
    user127 likes this.
  18. ScottWang
    Aug 23, 2012
    4,923
    776
    What do you mean, as this one?
    LT1498 - 10MHz, 6V/μs, Dual Rail-to-Rail Input and Output Precision C-Load Op Amps
    LT1498 datasheet.
  19. user127
    Jan 25, 2013
    12
    Thanks for the answers.
    Now I've encountered another problem. After the simulation I started connecting the different parts, one at a time, starting with the resistor divider. When I connected the oscilloscope over one of the resistors I got a good signal with lower amplitude, which is good. But when I connected the the DSP over the resistors the signal became distorted.Is it the input impedance that has something to do with it? If so, how should I modify my simple resistor divider so that I get a clean signal in to my dsp?
  20. Ron H
    Apr 14, 2005
    7,050
    657
    What are your resistor values?
