Redesigning the soldering iron!
solderotter
Joined Jan 27, 2014
6
Hi, we’re a team of engineering undergrads hoping to redesign the soldering iron. Specifically, we’re looking at making it safer and more usable by younger teens and children.
We’re looking for any feedback or advice you might have, especially if you have kids, so if you can spare a few minutes to fill out our survey, that’d be awesome. Or if you have any questions, feel free to shoot us an email at: <snip> . Thank you for your time and input!
https://docs.google.com/forms/d/14cAsPIbiU_jf09aFBU03nplbYuBtr0JpTPzrWEp4OFw/viewform
also, does anyone know why there is so much metal exposed towards the tip?
sirch2
Joined Jan 21, 2013
1,037
Just give them a soldering iron. I've been soldering since around the age of 10 and my kids have had a go at a similar age. You only burn yourself once or twice before you learn.
richard.cs
Joined Mar 3, 2012
162
I teach groups of 12 year olds to solder as part of my employer's "outreach" program. I really don't think it's necessary, but if you want to optimise a soldering iron for young children then I suspect you would want to redesign the stands and the handgrip.
Kermit2
Joined Feb 5, 2010
4,162
Less functional. That really does describe the probable result. Children must learn how to perform tasks in a way that is safe. Mentors must allow for mistakes, and kids must learn that some mistakes can hurt. A safer hammer? Use it wrong and you hit a finger. Lesson learned. A safer pair of pliers? Use it wrong a you get a bad pinch and maybe a little blood comes out. Lesson learned. Toss a 12 year old the car keys and wave goodbye? Hell no! You take them to a large empty paved area and ride with them giving instructions. Hand over a chainsaw? Again, Hell no! Making something dangerous safe for children requires an adult, using adult reasoning skills.
A soldering iron can burn flesh. An adult, using adult decision making skills, should decide if the child is ready to handle such a task and give proper instruction in the handling and operation of the tool. Making the tool 'safer' is good. Making it idiot proof is not how to handle it. That aspect is conquered by teaching the new user proper precautions that address the inherent dangers.
Nothing is foolproof, because fools are to ingenious. :)
Metalmann
Joined Dec 8, 2012
703
I always wondered that same thing.....?
Having a very small tip exposed, not so much for safety but for accuracy.....maybe a tip 2 mm in diameter.?
How about a .079 ball tip?:confused:
Alec_t
Joined Sep 17, 2013
14,330
Unless you have a very thick/bulky insulating shroud around the iron shaft the surface temperature of the shroud would be almost as high as the shaft temperature; so little safety benefit. A thick shroud would make handling the iron, particularly if soldering in restricted spaces, difficult.
mcgyvr
Joined Oct 15, 2009
5,394
This could be excellent for all the child labor in China... oh wait.. They don't care about safety.. :)
task has already been completed...in one form anyways..
Google.. "cold heat soldering iron"
GopherT
Joined Nov 23, 2012
8,009
I don't agree. There are plenty of things that can be done.
An auto shutdown feature for one. If the iron is not moving it shuts down after X minutes. Maybe some irons already have that feature?
If it has auto-shutoff, it should also have auto-start so it must sense when I am about to use it again and start heating so it is ready as soon as I need it. ;)
GopherT
Joined Nov 23, 2012
8,009
My wife bought two "cold heat" soldering irons for my kids at Costco about 4 or 5 years ago. They are useless because they use resistive heating (two micro pins) to heat the solder. I think they have a high voltage switcher inside to get enough heat. Also, their ultra thin solder must be used. You cannot solder to PCBs because of the micro-pin configuration and lack of power. We were only successful soldering 30 gauge or smaller wires. Just not enough power. They are sitting in the "useless junk" pile.
I don't know why I didn't return them to Costco or even allow them to be opened - my kids were already doing fine with a regular soldering iron.
spinnaker
Joined Oct 29, 2009
7,830
Well then you would really have something. A device that can read minds.
Seriously a reset button would do. You would just need to wait till it heats again. Not a big deal IMHO if it saves a ruined iron or worse, a burned down house.
wayneh
Joined Sep 9, 2010
17,498
I'm not impressed with the ergonomics of the traditional iron, and I think it could definitely be improved while retaining functionality.
For one thing, the cord placement is a pain. A pistol configuration helps a bit but that is usually seen only in guns with the transformer built in to the handset, which is not so good for small work.
Another pain is the long hot barrel that can burn fingers and insulation but is not functional for getting the soldering job done. I'd much rather have something like a nice pen with just a short hot zone at the tip. Lose the 3" of hot sleeve. A retractable tip would be nice but it's hard to imagine how you'd do that.
One good thing about the traditional iron that I'd hate to lose is the ability to rotate the tip. Sometimes a small rotation, say 30° one way or the other, puts the tip into the perfect orientation for making the solder joint.
wayneh
Joined Sep 9, 2010
17,498
An in-between solution could be an iron that cools 20° while in the stand but heats up as soon as it's withdrawn.
strantor
Joined Oct 3, 2010
6,798
Good! Now let's go to solve the problem of taking it from the wrong end.
I know someone who did it!
(It was painful, let me tell you...)
You're not dredging up something I said 926 days ago, are you?
I was holding the soldering iron like I always do - like a pencil. then, like I always do when I'm holding a pencil (and deep in thought about something), I flipped the iron over and palmed all 750 degrees of it. I actually held it like that >1sec. I heard the sizzle and actually had to look to see where it was coming from. Then I dropped it in my lap.
spinnaker
Joined Oct 29, 2009
7,830
I know you have a maritime background. In this country, we have a saying regarding sailing, "If you haven't been aground, you haven't been around".
Same deal goes with electronics. If you are around a soldering iron long enough you are bound to get burned in one way or the other. Same thing of getting shocked by touching an energized circuit.
