Is the switch spst and push button important in this circuit? I do this project without putting them in the circuit but it's not working.
All the led does not lights up.When open the toggle switch only removes power from the 555 circuit.
The reset button will cause +9v to appear on Q6 output when closed.
What part of the circuit isn't functioning correctly ?
Is the 555 generating a output is disconnected from the 4017 input ?
I draw the circuit using livewire and then i convert it to PCB. So this is the picture. Maybe it will help.When open the toggle switch only removes power from the 555 circuit.
Is the 555 generating an output ?
Output voltage at 555 only 1.4v
Is the reset pin being held low ?
Is pin 13, the clock inhibit pin (not clock 2 as shown) being held low ?
Are the LEDs the correct way round ?
All LEDs are connected correctly
Is the 4017 showing any signs of overheating ?
Yes
You said you omitted the two switches, what have you done in their place ?
I replace it with a straight wire bypassing it
You can't do that. You are holding the 4017 in a reset state. Bypassing the Reset which is a momentary push button switch with a straight wire will not work. For count to happen pin 15 Reset needs to be low. This is a CD4017 Data Sheet, you may want to read it and review it. Note on page 3-52 what is going on with the Reset pin.I replace it with a straight wire bypassing it
I have cut off connection between pin15 & pin16, and solder a wire at pin16 as a reset button like in the pic. Is it okay?If you have replaced the reset push button with a piece of 2 things are happening.
1: The 4017 is being held in a state of reset
2: Output Q6 is being connected directly to 9v
I suspect you may have damaged your 4017. Connecting the reset button and output Q6 both to the reset input is a design flaw.
A datasheet for the 4017 maybe of help.
by Aaron Carman
by Aaron Carman
by Jerry Twomey
by Duane Benson
