I want to take some LEDs off some circuit boards and use them in other projects. How do I find out their value and polarity?
I tend to agree. I don't scavenge plain resistors or small, common capacitors either for the same reason. When you go to build something, it's just so much better to have a nice array of new components on hand. It only costs a few dollars to set yourself up that way.LEDs cost like pennies on eBay. Not worth desoldering old leds for that price.
I just had an idea. For the heck of it I took a 3 volt button cell battery, taped a wire to each side and touched them to one of the LEDs on a junk circuit board and what do you know, it lit up. I switched the wires on the LED and it didn't light up. I tried a few more and the same thing happened. Hmmm, well I guess that's one way of doing it. I don't know if that's as bright as they could get with the low volts but they still work.
When resistance stays the same, doesn't current and voltage increase and decrease proportionately??? If so, voltage does matter.As long as the voltage exceeds the forward voltage, the amount of voltage applied has no effect on brightness. What matters is the current. But if you exceed the rated current then you can blow out the LED or at least limit its life.
LED's are polarity sensitive as shown in the diagram above. They will only light up with current flowing in one direction.I just had an idea. For the heck of it I took a 3 volt button cell battery, taped a wire to each side and touched them to one of the LEDs on a junk circuit board and what do you know, it lit up. I switched the wires on the LED and it didn't light up. I tried a few more and the same thing happened. Hmmm, well I guess that's one way of doing it. I don't know if that's as bright as they could get with the low volts but they still work.
Yes and no. Yes, the current driven through an LED varies with voltage. The problem is that the voltage range between <turn-on, very dim>, and <out-of-spec, exploding bright> is only about 1/2 volt. Worse, this range will vary from LED to LED, and will even vary with temperature for a particular LED.When resistance stays the same, doesn't current and voltage increase and decrease proportionately??? If so, voltage does matter.
Some of the cheap novelty key fob lights are literally just a LED and coin cell.I just had an idea. For the heck of it I took a 3 volt button cell battery, taped a wire to each side and touched them to one of the LEDs on a junk circuit board and what do you know, it lit up. I switched the wires on the LED and it didn't light up. I tried a few more and the same thing happened. Hmmm, well I guess that's one way of doing it. I don't know if that's as bright as they could get with the low volts but they still work.
they are not meant to be for permanent fobbing or professional useSome of the cheap novelty key fob lights are literally just a LED and coin cell.
White, blue and sometimes green have a stacked pair of 2016 cells, all the other colours have a single 2032.
They rely on the cell internal resistance to limit the LED current - it doesn't do the cell or the LED any good!
I guess you must've missed the words "cheap novelty" in my post.they are not meant to be for permanent fobbing or professional use
by Duane Benson
by Aaron Carman
by Aaron Carman
by Aaron Carman
