Hello:
We have an electronics box powered by 110VAC thru an IEC input connector. The unit does not draw more than 1A. We would like to have this box go through repeat cycle chamber testing.
The unit will be powered ON for a time frame anywhere from 3 minutes to 7 minutes (desire a random time in this range). Then power is turned OFF to our box for a fixed time of 30 seconds. After the 30 seconds, the box is powered up again for another 3 to 7 minutes random time. This process will repeat continuously.
I have an AC solid state relay module that has a 0-10Vdc control input. Therefore, we'll only need the desired trigger controller circuit to go to the AC Relay module that has the 0-10Vdc control input.
Any help or circuit diagrams would be much appreciated. I am also open to having a set time frame of, for example: 5 minutes, instead of the random range of 3 to 7 minutes ON time....should it be difficult to generate a random time range.
Thanks.
Thanks.
