Rectifying AC mains
Discussion in 'General Electronics Chat' started by Deuteron, Oct 27, 2015.
Thread Status:
Not open for further replies.
  1. Deuteron
    Oct 27, 2015
    Hello! This is my first post here and i am building a power supply by rectifying AC mains. The mains electricity 220vac will be connected to a 20A variac and then a bridge rectifier then a capacitor bank consisting of 8 1500uf 400v capacitors, giving around 12000uf in total. I am trying to use this to power a solenoid with around 15 A current. Do i need to add any current limiting resistor or inductor? Thanks in advance!
  2. Kermit2
    Feb 5, 2010
    3,852
    968
    You might consider a 10 ohm high wattage resistor for power up purposes. That would limit in rush current to about 20 amps. After the caps charge it can be bypassed with a switch or by relay.
  3. umphrey
    Member
    Dec 1, 2012
    39
    How about some NTC thermistors for inrush limiting? I've read app notes that recommend it but never built it.
  4. dl324
    Distinguished Member
    Mar 30, 2015
    3,379
    651
    If you don't want to be bothered with switching out a surge limiting resistor, NTC thermistors are the way to go. I have some 10 ohm 4A that drop down to less than half an ohm at 50% of rated current and 0.22Ω at 100%.
    Hope this answers your question because transformerless AC mains circuits are prohibited and this thread will be shutdown soon.
  5. GopherT
    Nov 23, 2012
    6,319
    4,043
    I'm not so sure. He said he was connected to a variac. Not completely isolated but, I think he is within the rules.
  6. crutschow
    Mar 14, 2008
    13,505
    3,376
    A variac is a non-isolated supply and likely not within the rules.
    To minimize the chance of electrocution when experimenting with a variac output without an isolation transformer, connect it to a ground-fault isolator (GFI) outlet or with a GFI cord such as this.
    You can still get zapped, but it's not as likely to be fatal.
  7. MrAl
    Jun 17, 2014
    2,562
    518
    Yes good idea, about the isolation transformer. They also make variacs that are isolated.
    But any voltage over 20 volts could be dangerous, and 220v certainly is over 20 volts so much care in handling of the circuit components with the power off is a good idea.
    Also, and i cant stress this enough, wear eye protection and stand away from the electrolytic caps especially when the power is turned on. I've seen caps blow their tops like little cannons, spewing all kinds of materials out. They sound like a gun going off too, so maybe ear protection as well. It will scare the **** out of you if it happens :)
  8. wayneh
    Sep 9, 2010
    12,391
    3,246
    You didn't mention what your solenoid voltage is. If you don't need the variable voltage given by the variac, it might be simpler and safer to just use a simple step-down transformer.
  9. tcmtech
    Nov 4, 2013
    2,115
    1,752
    I would say your design for a line powered variable DC power supply will work just fine.
    I see no reason for any inrush current limiting devices due to the amount of capacitance you are working with simply being you have a Variac and can start each power up at zero volts.
  10. Dodgydave
    Jun 22, 2012
    5,155
    772
    What's the solenoid voltage rating, and whats it used for?
  11. #12
    Nov 30, 2010
    16,704
    7,354
    Yes, a 5000 watt solenoid doesn't seem right.
    Please explain.
  12. ian field
    Oct 27, 2012
    4,456
    792
    Magic smoke generator?
  13. wayneh
    Sep 9, 2010
    12,391
    3,246
    "Solenoid" could be a euphemism for "rail gun".
  14. tcmtech
    Nov 4, 2013
    2,115
    1,752
    At that power level I tend to consider them as just starting to be fun to play with! :D
  15. ScottWang
    Aug 23, 2012
    4,933
    777
    Welcome to the AAC forum.
    The owners of All About Circuits has elected not to host discussions of transformerless threads.
    This thread is against the AAC forum rules, Terms of Service (ToS).
    Any kind of over-unity devices and systems
    Devices designed to electrocute or shock another person
    LEDs to mains
    Phone jammers
    Rail guns and high-energy projectile devices
    Transformer-less power supplies
    Transformerless power supplies of any kind are strictly forbidden. Therefore, this thread will be closed.
    Please try to understand the reasons behind this action, and feel free to browse and use the forums.
    You might find answers to your questions in one of these forums:
    http://forum.allaboutcircuits.com/showthread.php?t=54400
    Another good forum that shares many of the same membership is http://www.electro-tech-online.com/ .
    Good luck.
  16. DerStrom8
    Feb 20, 2011
    2,428
    1,329
    @ScottWang I think you forgot to lock the thread....
  17. ScottWang
    Aug 23, 2012
    4,933
    777
    Thanks.
    I always lock it first, but this times posted the TOS first, and forgot to lock.
    DerStrom8 likes this.
Thread Status:
