Rectifiers
Discussion in 'General Electronics Chat' started by TL314, Apr 14, 2015.
  1. TL314
    Mar 29, 2015
    64
    What would be some effects caused by an non-ideal rectifier?
  2. Papabravo
    Feb 24, 2006
    10,338
    1,850
    Exponential increase in current for small increase in forward voltage.
    TL314 likes this.
  3. OBW0549
    Mar 2, 2015
    1,389
    932
    Is this for homework?
  4. TL314
    Mar 29, 2015
    64
    Homework questions go in the homework section. Just a general question.
  5. Dr.killjoy
    Apr 28, 2013
    1,209
    157
    It's a hard thing to explain cause it depends on to many factors like the filter cap size ,age,esr and that's only one part ..
  6. TL314
    Mar 29, 2015
    64
    it wouldnt perfectly block current in one direction and transmit current in the other direction right?
  7. OBW0549
    Mar 2, 2015
    1,389
    932
    I would say a non-ideal diode (i.e., a real-world diode) would differ from an ideal diode in that it would show unit-to-unit variations in forward voltage and reverse current, as well as departures from the I/V characteristics predicted by theory. Most of these would be due to process variations and variations in the purity of the raw materials.
    On the other hand, you could say a non-ideal diode differs from an idealized diode in that it has any forward voltage drop at all, and leaks any reverse current at all.
    It all depends on what you mean by "ideal."
    TL314 likes this.
  8. #12
    Nov 30, 2010
    16,665
    7,313
    There is also capacitance across the real junction, reverse recovery time, and the heat that is caused by the current...if I didn't repeat anybody.
    TL314 likes this.
  9. wayneh
    Sep 9, 2010
    12,374
    3,225
    Let's not forget the voltage drop, and associated power loss.
    Ah, I see the previous posts already address this.
  10. hajivitra
    Apr 7, 2015
    13
    nice information
    thanks all
  11. TL314
    Mar 29, 2015
    64
    thanks!
  12. OBW0549
    Mar 2, 2015
    1,389
    932
    One really excellent resource for understanding the multifarious "non-ideal-ness" of all kinds of components is a book by Robert Pease, Troubleshooting Analog Circuits. Pease discusses all the quirks and foibles of resistors, capacitors, inductors, diodes, transistors, LEDs, opamps, comparators and sundry other ICs. The book is a bit pricey, but worth EVERY penny because it's simply chock-full of practical information.
  13. #12
    Nov 30, 2010
    16,665
    7,313
    How about just download any datasheet for any diode and expect that every specification listed is describing some characteristic that is not ideal?
    wayneh likes this.
