rectifier
Discussion in 'General Electronics Chat' started by mermerzac, May 16, 2012.
  1. mermerzac
    Feb 9, 2012
    30
    Hi all!
    I'm implementing diode rectifier with AC voltage supplied from centre-tapped transformer.
    The diode rectifier consists of 2 diodes and will be followed by a LC filter and 10ohm resistive load. This design was built on the printed circuit board.
    I obtained my waveform for Primary voltage of centre-tapped transformer, voltage across diode and the current flowing through diode.
    But looking at the waveforms, why the waveform is not rectified nicely? what is the reason causing the circled area to occur??
    Thanks very much.
  2. crutschow
    Mar 14, 2008
    13,496
    3,373
    What is the frequency and power level of the waveform?
  3. mermerzac
    Feb 9, 2012
    30
    switching frequency is 10khz while the input to the dc-dc converter is 60V. This rectifier part is actually the last part in my dc-dc converter. My dc-dc converter consists of dc-ac inverter, then followed by centre-tapped transformer and then this rectifier.
