rectifier
Discussion in 'General Electronics Chat' started by ryan200, Nov 19, 2008.
  1. ryan200
    Nov 19, 2008
  2. mik3
    Feb 4, 2008
    4,846
    63
  3. ryan200
    Nov 19, 2008
    hey, thanks for the link, but in fact i need to use a bridge rectifier. sorry for the confusion.
  4. mik3
    Feb 4, 2008
    4,846
    63
    You can use a center tapped transformer and connect one bridge rectifier between the center tap and one of the other taps and another bridge rectifier between the center tap and the tap which left. Then connect the negative side of the first rectifier with the positive side of the other rectifier to make a common point which will be your ground.
  5. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,389
