rectifier
Discussion in 'Homework Help' started by amjad..ali, Apr 12, 2015.
  1. amjad..ali
    Apr 12, 2015
    12
    Hi
    I need help with this project please
    single phase full wave control rectifier 2 pulse with load 10 watt
    I need to design the circuits and explain it
    help m
  2. Papabravo
    Feb 24, 2006
    10,340
    1,850
    This is Homework Help, not Homework Done for You. That means you need to show us what you have done to get started. You must show us something.
    amjad..ali likes this.
  3. bertus
    Administrator
    Apr 5, 2008
    15,799
    2,386
    The following PDF might not be perfect, but will give you information on rectifier circuits:
    Unit12.pdf
    Bertus
  4. amjad..ali
    Apr 12, 2015
    12
    thank you it's good
  5. amjad..ali
    Apr 12, 2015
    12
    in this image if i removed the diode and Placed a thyristor
    how can i find the value of R , Vr , Ir and the better type of thyristor for this circuits if i know the input is AC 220 volt and 50 Hz and power on the R is 10Kwatt
  6. MrCarlos
    Jan 2, 2010
    400
    134
    Hello amjad..ali
    You have two issues (Threads):
    1) - "Rectifier" Located in this link: http://forum.allaboutcircuits.com/threads/rectifier.109669/
    2) - "Thyristor" Located in this link: http://forum.allaboutcircuits.com/threads/thyristor.109677/
    Both are focused to achieve the same end, but give a different data.
    The known values mentioned by You, are:
    R = 10K Watts, Or R = 10 Watts. They are two different cases ??
    Voltage transformer secondary are 220 With center tap (CT).
    In your thread "rectifier" You say:
    -I need help with this project please
    I need to design the circuits and explain it-
    While in your thread "Thyristor"
    -in this image if i removed the diode and Placed a thyristor
    how can i find the value of R , Vr , Ir and the better type of thyristor for this circuits if i know the input is AC 220 volt and 50 Hz and power on the R is 10 K watt-
    What do you mean: control rectifier 2 pulse ??
    Why are you interested in finding the values: Vr, Ir.
    something else: what are these parameters for you ??. . . What are ??. . . Could You explain it ??
    To calculate the value of R just look at the attached image to find the formula.
    V x V / P.
    In your thread Thyristor, you mention that the secondary of the transformer is 220 with center tap (CT).
    so that you are applying, to the resistor, something like 110 V. RMS.
    Then:
    110 x 110 = 12,100
    12,100 / 10,000 = 1.21 Ohms, value of R. 1 Ohm 210 milliohms.
    But if We take the 10 Watts mentioned in your other thread the result will be different.
    12,100 / 10 = 1,210 Ohms, value of R. 1 thousand 210 Ohms.
    However:
    If we want to know the current flowing through the resistor, just go back to see the attached image; find that I = P / V.
    10000/110 = 90.90 Amp.
    In the other case
    10/110 = 0.091 Amp
    So: to select the Thyristor that fits the parameters described, you can do it THROUGH the following link: http://www.alldatasheet.com/
    Search by:
    100 Amp. Thyristor
    or
    1 Amp Thyristor
    According your case.
    But I think it would be best to look the other way:
    Question electronics stores in your area what Thyristor's they have, find them on the link above.
    Please consider the following:
    If your circuit is as you showed, only serve to purely resistive circuits. No other purposes. . .
    Could You please tell Me Why ??
  7. amjad..ali
    Apr 12, 2015
    12
    first thing thank you
    you are Genius this the perfect answer i want
    2nd
    the control mean there is thyristor supersede the diode
    and 2 pulse mean its full wave
    i interested in finding the values: Vr, Ir
    because i need to find the type of thyristor and resistance for this circuits
    is this the all data i need to design control rectifier 2 pulse ??
    and thank you again
  8. amjad..ali
    Apr 12, 2015
    12
    sorry MrCarlos
    but i'm not good in english
    about your question 'If your circuit is as you showed, only serve to purely resistive circuits. No other purposes. . .
    Could You please tell Me Why ??'
    this book can explain for you what i mean and what i want in fact ' but my Doctor need the project about 10 K waat on the load '
    https://books.google.jo/books?id=mR...trol rectifier 2 pulses centre tapped&f=false
    i'm really thank you
  9. MrCarlos
    Jan 2, 2010
    400
    134
    Hello amjad..ali
    Surely you know the answer but I think you're afraid to answer.
    The circuit you presented in your post #5 will have only: one rectifier diode and 1 Thyristor.
    In such a way that a full half cycle of the AC will be rectified.
    The other half cycle is the only one You can control its amplitude from almost 0 to the maximum. 110V RMS.
    So you have a pulsating current in R, with a full half cycle and the other variable in amplitude.
    This way, many harmonics are generated, electromagnetic noise, which are harmful to, for example, sound systems and/or digital systems, Etc.
    These systems require a source of polarization as pure as possible. without Ripple
    In contrast to purely resistive circuits will not affect them adversely because only be used to 'Heat' something through a resistor. For lighting also serve such circuits.
    But beware, the electromagnetic noise generated by these circuits can adversely affect other nearby equipment.
    To reduce this effect you must add a snubber network. You can find what is this snubber asking to Google.com.
