Please recall that for a sine wave, RMS voltage and current values relate to the equivalent DC values. Thus I will suggest that, for the most part, you stay with the RMS values for the analysis. For a DC motor application I think all you will need is suitably sized transformer and diode rectifiers and can eliminate any regulation circuitry including capacitors. As I suspect that a transformer with a 220/200 ratio may be difficult to obtain, a 1:1 isolation transformer may do the trick. Assuming a full wave rectifier, the resultant DC output will be 250 Vdc with no load. and somewhat below that when under load. If the output, under load, is 220 Vdc, this will be only 10% over the rated 200 Vdc for the motor. Motors, especially those of the ratings described, should be able to handle an applied voltage of 10 & over the nominal. Regards.
