I needed a rectifier for a new transformer I bought second hand. All I know is that it outputs 13.7 Volts. And I'm not very good at telling how many Amps it has by the size of it (~ 3 Inch each side), so I whould say that it is at least 2 Amps... but just in case, I want to use a rectifier that is more than 4 Amps...
I went to buy a rectifier to a local electronics store, and I basically had a choice between 4A 100V and 8A 400V.
Since I don't know the output Amps for the transformer, I want to use the 8A 400V rectifier.
But, is there a performance difference between the 100V and 400V when it will be used for only 13.7V ?
Also, if I use 2, 4 Amps rectifires in parallel, does that mean that together they are 8 Amps ?
