Rectifier Voltage Drop
Discussion in 'General Electronics Chat' started by Galibore, Jul 19, 2012.
  1. Galibore
    May 22, 2012
    20
    Hi Guys,
    Is it possible to calculate the voltage drop of a DBR if you know the input VAC? Or is it manufacturer specific?
    Thanks in advance.
  2. #12
    Nov 30, 2010
    16,705
    7,358
    Read the datasheet. It has a graph of forward voltage drop/current.
  3. cork_ie
    Member
    Oct 8, 2011
    348
    58
    If it contains standard silicon diodes, you will generally have about 0.7V per diode. Schottky diodes have a much lower voltage drop C. 0.2V but much higher leakage than silicon. If you have access to a datasheet then that is obviously the best option. If not most multimeters have a Vf setting where you can measure forward voltage
  4. Galibore
    May 22, 2012
    20
    Thanks guys. Appreciate it!
  5. russ_hensel
    Distinguished Member
    Jan 11, 2009
    820
    47
    Rectifiers are often run harder than signal diodes so voltage drops of over a volt are not uncommon. In a bridge you have 2 diode drops. RTFM is almost always good.
  6. cork_ie
    Member
    Oct 8, 2011
    348
    58
    1) I work on car alternators every day which have silicon diodes often carrying up to 30A and have never seen a diode drop more than 0.8 V.
    0.7V is a pretty standard value for the IN series and most bridge rectifier diodes are similar.
    2) Yes you are correct each diode will have a voltage drop so an overall drop of 1.5 V or so can be expected. Power dissipation of the bridge must also be considered e.g. 3 Amp rectifies will produce circa. 9 Watt.
