Rectifier VI Formulas
Discussion in 'General Electronics Chat' started by R!f@@, Mar 15, 2015.
  1. R!f@@
    Thread Starter AAC Fanatic!
    Apr 2, 2009
    8,787
    771
    Hey Guys.
    I got the attached pdf about the Secondary Rectifier formulas for V & I.
    Can any one confirm the formulas are correct.
  2. Papabravo
    Feb 24, 2006
    10,340
    1,850
    Are you unduly suspicious for some reason?
  3. R!f@@
    Apr 2, 2009
    8,787
    771
    Just to be sure.
    It will help to avoid certain unduly suspicions
  4. Papabravo
    Feb 24, 2006
    10,340
    1,850
    I should have been more precise. Do you have a reason to suspect any of the formulas on the page, or do one or more of them just look wrong for some reason.
  5. ronv
    Nov 12, 2008
    3,393
    1,452
    I have always used that page to derate transformers. I hope it's right. :rolleyes:
  6. R!f@@
    Apr 2, 2009
    8,787
    771
    I wanted to use all of 'em all the time so I need advice.
  7. Papabravo
    Feb 24, 2006
    10,340
    1,850
    I would say use it until you have a reason not to use it. I'm retired and I don't have the patience to grind through the analysis. If it makes you feel any better I didn't see anything that jumped out at me as wrong.
  8. R!f@@
    Apr 2, 2009
    8,787
    771
    Fair enough.
  9. MrChips
    Oct 2, 2009
    12,624
    3,451
    Those formulas are not accurate. However I have been using them as a guide as long as I can remember building power supplies. They are just that (guides) and are good enough for most purposes.
    Also Hammond transformers are rated conservatively, i.e. the rated voltage is for full load current.
    I have found transformers from a certain store R.S. to fall short of the stated specs.
    The moral of the story is - not all transformers are built the same.
    R!f@@ likes this.
  10. R!f@@
    Apr 2, 2009
    8,787
    771
    That is also fair enough.
