Rectifier/regulator for motorcycles 3 phase generator.
Discussion in 'The Projects Forum' started by ak_47_boy, Jan 29, 2014.
Thread Status:
Not open for further replies.
  1. ak_47_boy
    Jan 29, 2014
    The easy way (and the common factory way) would be to simply use a 3 phase bridge rectifier and zener and transistor to shunt excess power to ground to maintain 12V. I was thinking of using schottky diodes to gain a little more voltage at idle, although now i don't think its necessary after measuring the original 1970s rectifiers voltage drop at 2.5V with a 5 amps load. That is 5volts lost! I believe any decent standard modern rectifier should be less then 2.5V drop. That is already a 20% gain which is more then a $200 rewound stator will get you. Also i am thinking of changing from shunt to linear or switched regulation to prevent unnecessary engine loading and heat dissipation in the electronics.
    For interest stake i am thinking of better/more elegant ways rectifying and regulating 3 phase to 12Vdc. I think the best way would be mosfet H bridge arrangement, if there was a controller IC available this might be quite a simple arrangement with nearly no voltage drop? Another possibility would be using thyristors in place of 3 of the 6 bridge diodes, this might be the most simplistic and rugged approach, i found a simple schematic someone else drew of this.
  2. tcmtech
    Nov 4, 2013
    2,120
    1,754
    Common 50 - 100 volt diodes of today standards would show around .6 - .8 volts forward drop at 5 amps.
    That will pick up a considerable amount of lost power.
    Shottky diodes would cut those loses again by about half. That's where I would start for picking up extra power at idle.
  3. MrChips
    Oct 2, 2009
    12,652
    3,461
    Welcome to AAC. With regret I have to close your first post.
    The owners of All About Circuits have elected not to allow discussions of automotive electrical system modifications/enhancements due to safety concerns, the potential of legal ramifications and the possible circumvention of vehicle regulations at the state and federal level.
    This thread is against the AAC forum rules, Chapter 6, as seen here:
    This can be found in our Terms of Service (ToS)
    Motorcycle modifications still fall under the category of automotive modifications.
    Here is a site that may provide you with some assistance: Electro Tech Online
    Good luck.
Thread Status:
