rectifier question
Discussion in 'General Electronics Chat' started by automagp68, Jan 6, 2012.
  1. automagp68
    Nov 13, 2011
    81
    Hello
    Quick question on a test i have going
    I am testing 3 different bridge rectifier all solid state full wave
    One radio shack unit and another i built out of 4 diodes
    Signal source is a function generator simulating 60 HZ AC Signal
    It works but it look like half wave as there is no Frequency doubling. Just a flat spot in the wave where negative should of been folded up.
    Any idea what my issue is?
    It does this on all 3 rectifiers i have, both the store bought and the home made diode one.
  2. jimkeith
    Oct 26, 2011
    539
    99
    My guess is that you have a ground fault--signal generator common connected to scope common--isolate ground pin on one unit and see what happens--or connect scope as a differential input, if it has that feature
  3. automagp68
    Nov 13, 2011
    81
    can u explain the a bit more?
    EE student here 1st year
  4. automagp68
    Nov 13, 2011
    81
    Ah yes i know what u mean now i read it wrong
    No i am not sharing the ground
    Rectifier has 4 pins
    The Signal generator is on two of them + and -
    The scope prob on the other + and -
    No idea what differential input is?
    Its a Tektronix 2205
  5. Adjuster
    Dec 26, 2010
    2,147
    300
    The Tektronix 2205, like most oscilloscopes has coaxial inputs. The outer connection of the inputs will be linked to mains ground for safety.
    It is possible that your function generator has a similarly grounded output, which will create a short-circuit in your experiment.
  6. automagp68
    Nov 13, 2011
    81
    so how does one get around this?
    If this is the case then how does one use the scope for testing, if i cant see the doubling?
    And even if so i don't understand why this matters,
    I should only be looking at postive side of the sine wave any way, I understand the scope is grounded.
    Basically the scope says zero in the middle of the wave where it should have a peak. Like a half wave
    It is not possible to test rectifiers on a scope?
  7. Adjuster
    Dec 26, 2010
    2,147
    300
    You could do it using a source which is isolated, perhaps by passing the signal through an isolating transformer.
    Alternatively, you might do a differential measurement with two inputs subtracted, if the Tek 2205 scope supports that function. Edit: it seems likely that it does: there is an "ADD" vertical display option and Y channel 2 can be inverted.
    NB for correct differential mode operation, the Y channel sensitivity settings must be equal. Before engaging "ADD", but with Y2 already inverted, ensure that both channel displays are entirely on the screen.
  8. w2aew
    Member
    Jan 3, 2012
    219
    64
    The problem is that the output of your signal generator is grounded too. So it's connecting one node of your bridge to ground, and the scope is connecting a different node to ground.
    In most applications of full wave bridge rectifier circuits (power supplies), the AC drive to the bridge is coming from a transformer - neither of the two connections are grounded. If you transformer couple your signal generator to the bridge, it will work fine.
    The other thing you can do is make the scope measurement differentially. Use two inputs to the scope. Use channel one to measure between ground and the + output of the bridge, and CH2 to the - output of the bridge. Then, set the scope to invert CH2, and set the vertical mode to ADD. This will create a pseudo differential measurement across the + and - outputs of the bridge.
  9. w2aew
    Member
    Jan 3, 2012
    219
    64
    Hah - you were faster on the keyboard than me!
  10. automagp68
    Nov 13, 2011
    81
    Hi thanks for the idea
    So instead of using two channels i just made a common ground instead , because u said it was connect to a different ground.
    That did not work of course or im sure u would have suggested it.
    Why is that
    Also so i set up the scope like u suggested but can u explain what goes on channel 2
    Probe to the - output of the bridge and where does the ground go?
    I cant seem to get that to work
  11. Adjuster
    Dec 26, 2010
    2,147
    300
    I don't really know what you mean by that, but whatever ground arrangements you try to make, the mains ground is still there. (And it has to stay there - don't even think of trying to disconnect it as this is extremely dangerous. )
    Try drawing the circuit on paper, including all the ground connections. The cause of the short-circuits will probably become clear to you.
    I have to go now.
  12. automagp68
    Nov 13, 2011
    81
    Can any one explain where channel 2 goes for this type of measurement
  13. jimkeith
    Oct 26, 2011
    539
    99
    One probe goes to the anode of the bridge (+), while the other probe goes to the cathode (-).
    Both channels must be set at the same sensitivity and channel 2 must be inverted.
    The scope probe ground leads are not connected in this case.
  14. w2aew
    Member
    Jan 3, 2012
    219
    64
    Your function generator most likely has a coaxial output that you are connecting to the AC ports on the bridge. The shield connection of the coaxial output of the generator is GROUND. Thus, you are connecting GROUND to one side of the AC inputs of the bridge.
    The scope inputs are coaxial also. The shield connections of the CH1 and CH2 are also GROUND. Connect these GROUNDS to the same exact place as that you connected GROUND of the function generator. The center connections of CH1 and CH2 then connect to the + and - ports of the bridge. Then, invert CH2 and select the ADD vertical mode (both are settings on the scope)
    I don't know how to make it clearer than that.
    Of course, this will only work IF the function generator swings above and below GROUND.
  15. automagp68
    Nov 13, 2011
    81
    Ill work on it
  16. Maged A. Mohamed
    Member
    Apr 6, 2011
    18
    Hi
    please put the scope input on your signal generators output - no other things- be sure that the output of signal generator is symmetrical around zero volt, and the output is ok as you expect
  17. automagp68
    Nov 13, 2011
    81
    Hi yes
    The signal gen give me a proper sine wave on the scope
    thanks!
  18. automagp68
    Nov 13, 2011
    81
    wish i had an isolation transformer to replicate AC Sine wave correctly
  19. Audioguru
    Dec 20, 2007
    9,411
    896
    Thanks for wasting our time because you didn't bother to show your schematic 18 posts ago.
  20. spinnaker
    Oct 29, 2009
    5,114
    1,195
    Wow now I have a use for that Add button on my scope :)
