Rectifier Help
Discussion in 'General Electronics Chat' started by FenrirReturns, Mar 30, 2007.
  1. FenrirReturns
    Mar 30, 2007
    I have a rectifier (3 phase I believe, with 6 diodes) that has three terminals on it:
    I also have three wires coming from my alternator, now this is probably going to be a stupid question, but if I put one wire per terminal for input, where do I get power out of?:confused:
    Also for certain applications another diode trio could be used, but I'm not sure if I need it, either way with a multimeter I measure voltage in, but no voltage out
    Any advice at all would be a great help
  2. mrmeval
    Distinguished Member
    Jun 30, 2006
    833
  3. FenrirReturns
    Mar 30, 2007
    I actually already have the parts, I'm trying to use the rectifier by itself. And managed to solve the problem :D ! The original alternator used to have a battery terminal that would touch the powered side of the rectifier, which of course didn't come with it. You wouldn't believe how long it took me to figure that out, oh well :rolleyes: Now my issue is getting the right amount of power to my battery, some says they managed it without a voltage regulator, but I don't know how as I generate almost 40V!
  4. goodbyegti
    Apr 28, 2004
    59
    That's one of the reasons why you should never disconnect a car battery with the engine running!
