Rectifier filter
Discussion in 'General Electronics Chat' started by Kaiser Ed Bayawa, Feb 16, 2016.
  1. Kaiser Ed Bayawa
    Mar 19, 2015
    60
    6
    I am having a problem with my power suppy. The 12v transformer, I used bridge rectifier and a capacitor 2200uF filter.
    But still the output is not smooth.
    Do you have any idea about this filter?
  2. ronv
    Nov 12, 2008
    3,398
    1,455
    It should work, but the ripple will depend on how much current you draw from the supply.
  3. #12
    Nov 30, 2010
    16,685
    7,322
    Sqrt2 C Eripple(p-p)F = I
  4. MrAl
    Distinguished Member
    Jun 17, 2014
    2,554
    515
    Add more caps in parallel, that makes it smoother.
    To get very smooth you need a voltage regulator.
  5. cmartinez
    Jan 17, 2007
    3,698
    2,779
    Can you post a very simple, hand-drawn diagram of your circuit?
  6. wayneh
    Sep 9, 2010
    12,382
    3,238
    You've gotten two solutions, more capacitance or a voltage regulator. There may be other solutions if you give more details about the rating of the transformer and the load you need to power.
  7. Kaiser Ed Bayawa
    Mar 19, 2015
    60
    6
    the transformer rating is 12V and 0.75A
  8. AnalogKid
    Aug 1, 2013
    4,691
    1,297
    With the schematic you posted, the output never will be "smooth". Ever. It always will have some ripple. Increasing the size of the capacitor will decrease the ripple amplitude, but it will not - cannot - eliminate it.
    ak
  9. dannyf
    Sep 13, 2015
    2,196
    417
    define "smooth".
  10. ErnieM
    Apr 24, 2011
    7,436
    1,626
    Define smooth = how much peak to peak ripple can you allow?
    If that is zero you need a voltage regulator. If some number tell us what The lad R is and we can show you how to calculate how much capacitance you need.
  11. alfacliff
    Dec 13, 2013
    2,449
    428
    your circuit is of a simple "brute force " filter. more capacitance is need for this type. even with a regulator, more filter cap would be needed to prevent the regulator fromj dropping out under load.
  12. Kaiser Ed Bayawa
    Mar 19, 2015
    60
    6
    i used the term smooth for "no ripple voltage" or less fluctuation.
  13. dannyf
    Sep 13, 2015
    2,196
    417
    "no ripple voltage" and "less fluctuation" are two totally different things.
  14. cmartinez
    Jan 17, 2007
    3,698
    2,779
    The latter is readily attainable... but the former would be a holy grail hidden in neverland...
  15. ErnieM
    Apr 24, 2011
    7,436
    1,626
    For a 2200uF cap, 60 cycle full Wave bridge with the full load of 0.75ma one should expect on the order of 2.8 volts peak to peak of ripple.
    Doubling your cap halves that number. Ten times the cap drives it down to just 0.28 V p-p.
    (edited to add spec'd load current)
  16. wayneh
    Sep 9, 2010
    12,382
    3,238
    Those depend on the load. No load, (almost) no ripple. Loading at double the rating, big ripple, and the cap does little except increase the total load.
  17. ErnieM
    Apr 24, 2011
    7,436
    1,626
    My bad. Numbers are based on the quoted full load. Post 15 has been edited.
  18. wayneh
    Sep 9, 2010
    12,382
    3,238
    I knew what you meant. What we don't know is what the TS is doing.
  19. ErnieM
    Apr 24, 2011
    7,436
    1,626
    Understood. I was just trying to let MrAl know what was to be expected from his set up.
