kindly suggest the design method to make a 150kv rectifier circuit using diodes of 4kV/5A rating connected to a 50kV 100mA 3phase transformer.
<SNIP>
<SNIP>
Is this related to the Marx Generator (impulse generator) in your other thread?kindly suggest the design method to make a 150kv rectifier circuit using diodes of 4kV/5A rating connected to a 50kV 100mA 3phase transformer.
Nice, the good old days. When polychlorinated biphenyl (PCBs) transformer fluid was still called "pyranol". Pyranol is now used for a different class of molecules.I found this old abstract on a rectifier stack built by International Rectifier.
Interesting. This picture appears right side up on my iPad but not on a PC running Chrome.
I worked all day to figure out how to do that....Interesting. This picture appears right side up on my iPad but not on a PC running Chrome.
The attachment has real good information...thank u very much for the same..few doubts ive.I have worked on several high voltage supplies. The highest voltage was rated for 60KV. They all used conventional diodes stacked in series. Each diode had small capacitor and a resistor in parallel with it. I don't remember the typical values.
1. The design of the rectifier modules would not change. The circuit would.The attachment has real good information...thank u very much for the same..few doubts ive.
1.If the transformer used is single phase, does the deisgn of rectifier changes??
2.what is the criteria for selection of range of resistor to be connected in parallel to diode?
3.for capacitor the voltage range can be selcted by no. of capacitors n total voltage.but what shall be the capacitance of capacitor
by Duane Benson
by Duane Benson
by Jake Hertz
by Jake Hertz
