Rectifier circuits
Discussion in 'Feedback and Suggestions' started by jrap, Apr 14, 2007.
  1. jrap
    Thread Starter Administrator
    Jun 25, 2006
    966
    202
    Hey everyone, received the following email:
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Did he mention a source for positive-only diodes? They might be handy for use with my AC battery.
  3. JoeJester
    Apr 26, 2005
    3,390
    1,211
    I didn't see anything wrong with the ebook.
    I'm thinking he is using conventional flow -v- electron flow, or his instructor is explaining it improperly.
  4. mozikluv
    Jan 22, 2004
    1,437
    maybe "swaroop" has already been enlightened by going back to his books. but i do believe many are confused by this concept of "conventional current flow" & "electron flow" I would like to quote from a book from Texas Inst and later in its 5th edition edited by Don L. Cannon Ph. D. and i quote,
    "The direction in w/c electrons can pass is opposite the direction in w/c the arrowhead points. Electrons flow within the diode from cathode (K) to anode (A).
    You may wonder why the diode symbol arrow points opposite to the direction of electron flow. In circuits, we like to use a current flow opposite to electron flow. Electrons flow from more negative voltages to more positive voltages. Circuit descriptions use an imaginary current that flows from more positive voltages to more negative voltages. This imaginary current flow called conventional current. The diode symbol points in the direction of conventional current flow, since it is a circuit symbol. The conventional flow is the direction current would flow if the flowing particle were positively charged. Physically we see that current is due to negativelycharged electrons flowing in one direction. This is equivalent to positively charged particles flowing in the opposite direction. In physical description of devices , we tend to use the physically meaningful electron flow. In circuit description, the conventional current tends to make our circuit simpler to understand. "
    hope this unravels the confusion in this issue.
    moz
  5. Dave
    Retired Moderator
    Nov 17, 2003
    6,960
    145
    Further to the information provided by mozikluv:
    Conventional against electron current flow is also covered in Volume I - Chapter 1.7
    jrap, can I suggest that you reply to swaroop and bring to his attention this thread were he can ask further information if required.
    Dave
