rectifier circuits
Discussion in 'The Projects Forum' started by antony.prathiban, May 20, 2008.
  1. antony.prathiban
    May 14, 2008
    24
    can we use igbts and mosfets in the rectifier circuits instead of diodes and scr?
    what are the factors to be considered?
  2. Papabravo
    Feb 24, 2006
    10,340
    1,850
    I don't think so. Moreover why would you want to do that?
  3. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Can't see where IGBT's would be of help, but MOSFETS would reduce the voltage drop that's inherent in silicon rectifiers. The problem would be getting them started; you'd need some silicon rectifiers to "jump start" the gate drivers.
    You'd only want them conducting when the voltage across the MOSFETs was of the correct polarity to charge the filter caps.
