rectifier circuit
Discussion in 'Feedback and Suggestions' started by sumitest, Mar 14, 2016.
Thread Status:
Not open for further replies.
  1. sumitest
    Mar 14, 2016
    hello everyone,
    I have made full wave bridge rectifier circuit using IN4007 diodes. As per the theory we all know if my input voltage is below the threshold of the diode it will not conduct but in my case I'm using signal from function generator if I give 4V rectifier is working very well but it is also conducting when supply is 1V only. I don't the reason pls help me out from this problem.
  2. StayatHomeElectronics
    Sep 25, 2008
    864
    40
    Here is a diode curve, from the AllAboutCircuits chapter on semiconductors, chapter 3.
    To simplify the math we idealize the curve to show that current flow only occurs if the diode voltage, VD, is above 0.7 V. From the non-idealized graph above, we can see that current still flows when the diode voltage is below 0.7 V.
  3. crutschow
    Mar 14, 2008
    13,508
    3,384
    Why have you double-posted the same question?
  4. Wendy
    Mar 24, 2008
    20,772
    2,540
    One thread is enough and this is the wrong forum to post it.
Thread Status:
